Hi All,
I've finally settled in a permanent location and hoping for some advice on building a sound system for the living room, with the goal of ultimately putting together something that can be used as a 5.1 system too. I took a visit to the B&O store, which suggested that the below might work well:
TV: Beovision 11 - 46 or 55
Fronts: BL18 or BL20 or BL5
Rears: BL17 or BL3
Sub: BL19
I would greatly appreciate any advice on the above combinations, particularly the BL5 and BL3 as I wouldn't have a chance of hearing them in person. Or if there are any other products which you think might be a better fit. I appreciate that the options for the fronts are at quite different pricing levels, but I guess the question is more around if you were building a system, would you spend the extra $$$ on the BL5 vs the BL18, and are there any issues given the BL5's are no longer produced?
I was also advised at the store that if I were to run a projector, I would need a Beosystem 4 to run the setup, but would love to confirm if this was true.
Thanks a lot in advanced!
Best,
Jayson
