Home Cinema set up- the choice is endless..... NO!?
Having just been emailed by "ball park figure" for my Home Cinema Set Up" from my local BnO dealer & based on the fact of it coming in at £27,500..does anywon have any comments .
BTW qoute includes the followinh:-
Stewart Screen 92" visionary
Samsung SP A800 Projector
Beosystem 3 DBVT
Future Automation PD2 lift
Addiditional  7.2 centrer speeker
Beo 5
DVD 2 DVD player
 Cables & connections
Planning, Installing, commissioning. include 1x full time project manager..
Dont get me wrong Ididnt think it was gonna cost me a FIVER but in my experience its always best to ask around...
Sounds like a complete rip off to me. If you add up the cost of the hardware it dosn't come to much. How the hell they ended up at that figure is beyond me.
Get your head stuck in some Home Cinema magazines and get some other quotes.
Does there quote include building you an extentsion at the back of your house.
Just my opinion.
Sounds about right if you then include some of the higher end BeoLabs. Looks as though there are products missing off that list though. A BeoLab based surround sound system can cost between around £7k and £35k.
At least from my point of view it is very hard to comment because the "hardware" is just one part of the solution. So what is included and have they done simular projects before? Any references  you can check out?
My expirience with the Beoliving concept is that most of the dealers are unable to deliver a "full" cinema expirience as the only sell the B&O stuff. But in the real world there is more....just as an example the screen: Stewart is without any doubt one of the best products available, but they offer different screen materials which need to be selected with care to achieve the best result. (e.g. Firehawk vs. Greyhaw vs Studiotec, Multimasking system etc)
One aspect which I never saw in a Beoliving concept is room acustics. The room treatment is one of the most important aspects of a succesful cinema expirience. (even the Bang&Olufsen Demo room in Struer (downstairs just behind the B1 shop) has a very bad acustic...).
What is their take on the projector? The Samsung is a very outdated model (released 2005), not very silent and has some really nasty DLP drawbacks (from my expirience).
Furthermore, how is the light controll done? With Lutron, EIB? How many lights? Curtains?
Finally a ISF type of calibration would be something I would expect
So you may want to ask some more questions to the project manager to see what they can do for you.
 Hope that helps a little bit
Karsten
If it's all included, it's sounds OK. BUT DVD 2 is a no go. BS3 can control other brands Bluray players, so go for HDR2 instead it works in harmony with BS3.
You say " Addiditional  7.2 centrer speeker". My opinion that the price is way over the top was on the grounds that you already have your main speakers.
You can buy alot of nice kit for that money.
As usuall, some fantastic responces. a total MIXED BAG  as it were...
I especially like the comment on "accustics"
As for lighting, yes i have my own Lutron Graffik Eye  controller already installed with precision placed psots already in place.
As for pricing.. yes ive found out that BnO are charging the projector at £4995.00 & yet found it online @£2995.00 just know...
I guess i really like the idea of "one button go" on the remote...
As for the extension.. LMAO!😁
I go now to research even further.. infact just been looking at a rather nifty Sound Proofin' company online for such projects.. & yes ODD that BnO didnt mention this... Im sure my semi det neighbours would have something to say about it...
The projector can be had for £2300.oo online. Your freindly B&O dealer is charging you over double that. Just walk into their showroom with your trousers down to your ankles and bend over :-)
Like I said earlier..........complete rip off.
Looking at it, I would ask around too. While the B&O equipment is expenses, it seems like a lot for the labour. I would go for either a better projector or a cheaper screen. Seems a bit like connecting a Bose system to BL5.
 You can still buy the B&O equipment and have the pro installation done by someone else. I would ask to break that out.
In such a project which includes hardware, planing, project management and the "proof" that all the components "really" work together just changing hardware components must be seen in a different light. Most of the stuff just works by max 90% when you hit the cinema button on your Beo5. So with the installers expirience he usually selects products which work by 100%....just to avoid that you call him every second day.....
You may want to check the www.avsforum.com, there are lot debattes why a installer did select A instead of B (one example is a video server to store DVD on hardrive, they all go for the very very expensive Kaleidescape System as all the DIY media PC solutions are not working 100%)
With the B&O Beoliving concept they proofed it with the components they suggest. Unfortunately some of them are a little bit outdated....
What type of movie do you watch more? is that more 4:3/16:9 or more movies in cinemascope? If latest, than a multimasking screen or a 21:9 screen could make sense. I have a multimasking screen which great to adjust the black bars to the size of the movie, no white left overs!
Is your Lutron Grafik Eye the B&O one? because the beoliving concept works with IR, not with RS232 or IP (like Crestron, AMX or the new Philips .
At the end of the day the whole integration is based on the two triggers of the Beosystem 3 (screen controll, light scenes, curtains), the IR control of the projector from the BS3 with a cable and the IR light control of the Beo4/5 to a Lutron Grafik Eye or Busch&Jäger EIB panel. Not more!
Karsten
