Hi all,
I've recently purchased a beosound 9000 which I will be mounting in the living room. I don't yet have b&o speakers for the lounge, instead an A/V receiver, passive speakers and a samsung tv connected to the receiver. The tv's internal speakers are disabled and always uses the receiver for sound output.
I also have a BV 6 in another room which I would connect to the 9000 via masterlink and may possibly get a beosound 3500 for the bedroom, again masterlink.
I'd like to get some beolab 8000 speakers for the living room to replace the amp and passive speakers and originally thought I could simply connect the TV to the 9000 through aux-in but now realise that if for example I was listening to the radio on one of the remote masterlink speakers and the kids turned the tv on downstairs the masterlink speakers would switch to the TV/aux source.
My question is would a NL/ML converter with IR eye located in the living room resolve this by using the converter's AUX in for the connection to the samsung tv, it's powerlink to the beolab 8000s and masterlink to the 9000, BV6 and 3500?
Could the Nl/ML converter be used in this way allowing for the remote masterlink speakers to play a cd or radio from the 9000 while the beolab 8000s on the converter play the Aux in source?
Many thanks in advance,
Rob.
