Help with beosound 9000 & multiroom with 3rd party tv on aux-in
Hi all,
I've recently purchased a beosound 9000 which I will be mounting in the living room. I don't yet have b&o speakers for the lounge, instead an A/V receiver, passive speakers and a samsung tv connected to the receiver. The tv's internal speakers are disabled and always uses the receiver for sound output.
I also have a BV 6 in another room which I would connect to the 9000 via masterlink and may possibly get a beosound 3500 for the bedroom, again masterlink.
I'd like to get some beolab 8000 speakers for the living room to replace the amp and passive speakers and originally thought I could simply connect the TV to the 9000 through aux-in but now realise that if for example I was listening to the radio on one of the remote masterlink speakers and the kids turned the tv on downstairs the masterlink speakers would switch to the TV/aux source.
My question is would a NL/ML converter with IR eye located in the living room resolve this by using the converter's AUX in for the connection to the samsung tv, it's powerlink to the beolab 8000s and masterlink to the 9000, BV6 and 3500?
Could the Nl/ML converter be used in this way allowing for the remote masterlink speakers to play a cd or radio from the 9000 while the beolab 8000s on the converter play the Aux in source?
Many thanks in advance,
Rob.
Hi and welcome to Beoworld.
A NL/ML Converter won’t be of any help in your setup.
That converter is basicly a bridge between NL and ML product - you have no NL products in the setup.
ML systems are based on a Master and one (or more) slaves.
Therefore you can only use the Master/yourBS9000 once at the time.
Your conclusion is right ——- with one pair of rainboots only one person at the time can take a walk on a rainy day ;-)
There are however, a few exceptions from this = the BS4 and the BC2 - but that won’t help you!
For more information on setting up your products/ML/MCL have a look here:
Hi Rob,
Welcome to Beoworld!  Basically, you have two options if you want to link the non-B&O TV and the Beosound:-
1) Connect the TV and all of the Beolab speakers to the Beosound music system for stereo sound through all speakers, with volume control from the B&O remote, or
3) Use the existing AV receiver (ideally this would be one with pre-out sockets but that isn't essential) to allow all of the speakers to be connected for full surround sound with control from the receiver remote control.  In this case, the Beosound can link to the receiver to share the speakers.
For either of these setups, a Masterlink cable will give you music from the Beosound to the B&O products in the other rooms:
Thanks for the reply MM.
I presume if I had a NL b&o TV and the NL converter, the TV would be able to play CDs from the BS 9000? Would the remote ML speakers be able to play the TV source? I also want to add in a Chromecast Audio, in that set-up would it go into the AUX of the BS9000 or the AUX of the NL/ML converter?
Many thanks,
Rob.
Thanks for the advice Steve, I was in touch with via email last month re ML cable :) I think what I will do for now is link the BS9000 to the receiver via digital coax and masterlink it to the other ML products. Are you saying the beolab 8000 speakers could be connected to the denon A/V receiver? Just checked and it does indeed have pre-outs. It also has a switched A/C outlet rated max 1000W.
Rob.
Hi Rob,
Yes, you can link the Beolab 8000 speakers to the pre-out sockets of the receiver with these cables, this way you will get surround sound (with four or more speakers) rather than just stereo sound if they are connected to the Beosound:-
link
The Beosound can link to the digital audio input of the receiver with a co-axial cable to play CDs through the speakers:-
link
The other B&O products around the house can link to the 9000 via Masterlink cables:-
link
You then just need a Speaker Sense Adapter for the Beosound (this plugs into either Powerlink socket on the Beosound 9000 to allow it to accept commands from the B&O remote control without having B&O speakers connected):-
Many thanks,
Rob.
Yes, exactly that is the purpose of that converter...to exchange sources to and from both systems.
If you want to keep the receiver in the mix, you certainly can do as adviced from Steve.
If you however, want to get rid of it, you could have a look at this:
Thanks for your help.
If I upgraded my TV to a BV7 or BV10 would I connect the Beolab speakers directly to the TV and connect the BS9000 (also in living room) and other link rooms to the TV's ML socket? I would want to be able to play the radio or CD from the BS9000 in a ML link room while the BV in the living room was on TV, would that be possible? Would the living room BV be able to play sources on the BS9000 too over ML?
Many thanks,
Rob.
Hi MM, I'm toying with the idea of getting a beovision 11 with NL/ML converter as opposed to a BV7 or BV10.. do you know if a BV11 can play audio sources from an master linked BS9000 without having to turn the screen on? I couldn't see any reference to this in the manual. Many thanks for your help, Rob.
Sorry Millemissen but i think you are wrong here. It would be of little help since he can reach one of his goals with an NL/ML:
I have this setup with a little different devices:
Samsung TV > Optical out > DAC > NL/ML with IR-Eye > Beolab 8000+2.
On top of that i have a Beo4 Oneremote that controls my Samsung TV but regulates volume on the NL/ML.
Behold that the S8 HUB will do exactly the same for you but it does not give you the ability to distribute the Samsung TV sound to other rooms in Multiroom. So if you don't care for that the S8 Hub could be a solution for you.
Besides that i have a BS7000 > 1611 Converter > NL/ML Converter.
The NL/ML converter is setup so when i press Phono on the Beo4 it starts the Beogram and plays music on the speakers.
If i press TV the TV turns on and the NL/ML goes to AUX and plays TV sound. The only hiccup is that i have to select NL/ML AUX on BOTH AUX and TV command. If i don't the NL/ML sometimes will choose another AUX input. I have talked to support and they can't explain it.
The rest of the house is NL Products. I can stream sound from the Samsung TV to the NL products. I can watch TV in the livingroom and stream the TV to some NL products while i play a record on the BS7000 and stream the record to other products.
With the prices of NL products i have slowly sold all my MCL and ML products and bought NL products instead.
The only thing i have yet to try is to match an old BV8 with ML to the system. I look forward to see how it reacts.
