The silver cover has come off my 7.2 Beolab Soundbar which is attached to my 7-40 tv and I cannot get it back on.
As i understand the covers slide on and off from the side, but as it was knocked off by mistake by a decorator it seems some of the lugs may have broken and when I tried to slide it back it just fell off.
Also a couple of pieces in the middle of the speaker and underneath the grey cloth were loose.
I am reluctant to glue(super glue if possible) but if anyone has a better idea or solution I would appreciate a reply. If no ideas what would be the best way to glue it?
T
