Help, What happend??
Help, What happend.
Did my Beovision just died??
The screen turned purple.
If you expect some help you need to provide more details.
pdebruijn wrote:
Not very helpful....😮
What kind of details you want more??
The screen is purple when it’s on.
The sound, however, is still normal!
Hello, yes I’m afraid.
The Video Engine has to be replaced. There is no other solution.
Sorry, the image was not visible at first.
As "Pat" mention, this is probably a video engine problem.
Suggest you contact your dealer.
