Hi Beoworlders,
I have a Mac Mini hooked up to my Beovision 7-40 with a DVI to HDMI cable.
After checking the forum up and down I realized, I need some more electronics to get a proper 5.1 sound out of my speakers.
I went to my electronics dealer and bought:
- Toslink to mini jack adapter
- Toslink cable
- Toslink to Coax Converter (exactly the one that got posted here in the forum)
- Coax Cable (Cinch) 75 Ohm
After installing everyting I am a little lost with the setup as I simply don't get any sound :-(
My BV7-40 (TV only version without DVD player) has the following connections:
Physical: AV1 / AV2 / AV3 / AV5 (what happened to AV4 by the way???)
There is AV6 in the setup menue but I can't find it as well (maybe the connection panel on the side is AV6?)
Is there any special setup I have to do or must I register the Mini under a certain product group?? ...
You see me with a big "?" sitting behind my Beovision surrounded by cables with no idea left..
Help pls :-)
Best
Stephan
