What is going wrong here? Any suggestion is much appreciated.
Help needed: installing Beolink active
Did you try to connect the BL4000 to another system in the house?
Are you sure that it works?
Yes it works - it is my rear loudspeaker in the main system.
This happens both, when using beo 4 and/or the ir eye of the active module.What does this mean?What type nr. is the active? 1616? 1636?What is the Software Version?What command do you use to activate the active? A.AUX? TV? DTV?Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
It is a 1636 with sw 1.6.
activation beo 4: Radio (BC2)
activation ir: „Play“
Are you sure, that you have used the PL output to connect the BL4000 (and not the PC input)?
Yes - it is connected to the pl socket.
Good idea Ralf, i will see if I can find an adapter for my phone and check PC Input tonight.
For the time being: Is there a special sequence how to power up the system (e.g. TV first and link room thereafter ... or power up active first and plug in masterlink thereafter .... or something else?)
Also: i joined the masterlink „like for like“. I somehow remember that zwo wires could (should ?) be joined together: pink and white/blue. Could this be a the problem?
Thanks for your support.
You know that you’ll need a special cable for this - not just an ordinary 5-pin DIN adapter!!!
I understood that you already have a ML network running
and
if the ML-plug works for a BS2000, it is not likely that the fault is in the ML connection.
