Help needed Beocenter 9500 - cassette player
Hi to All,
I've just bought Beocenter 9500 and have issue with cassette player. The overall condition of the Beocenter is excellent but I can't use cassette player as head blocks insertion and removal of cassette. It just keeps still and no reaction to buttons. Do you know what could happened? Is it complicated to repair? What are your recommendations?
Thank you for your help in advance!
Max
Hi Max,
probably only the belt got old and loose so that the head unit can't be moved by the belt anymore.
Martin (Dillen on site) can supply belts and instructions on replacement.
Thanks Peter for information. I've already contacted Martin. We will see. It was difficult to replace the belt? How much of the Beocenter you have to disassemble?
Max
