Help my Beo4 work with my sky box!
Very precise positioning of the sticky thing is important. Trial and error with two people.
Get someone to repeatedly press a number while you move it about. Make sure you pressed Sat or DTV first!
By the way, Welcome Beoworld!π
Andy T.
Have you tried rebooting your sky box. Mine has a habit of locking up from time to time. Just unplug it leave for 10 seconds and then plug it back in. Never had any problems with the position of the blaster.
Craigπ
Hi guys, im new here so bear with me. i got a beovision 9 with sky+hd about 2 years ago, all installed by b&o. beo4 remote worked fine with the sky box up until recently when it just stopped controlling the box, though its. i've had to revert to using the sky remote on the box seperately. i have tried plugging the box out completely and removing all previous stored settings but same result. any help is much appreciated.
thanks
david
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
