Hey ! I'm a french student and i just purchased one of my dream turntable. A Beogram 1203 !
I have changed the belt but the auto arm isn't working properly. I have the service manual but it's in pdf and blurry when you zoom in si i can't do much.
My problems are :
- turntable is slow to get to the right speed even with a New belt.
- when i plug the turntable, it starts spinning immediately and i have to guide the arm to the center of the platter to stop it from spinning.
- the arm doesnt lift enough to go on the record so it's getting blocked on the side of the platter.
- the arm, when i lift it up enough with my finger, don't places itself at the start of 7" and 12" records but randomly on the midlle.
When i press the Burton while running. Nothing happens.
- when it reached then end of a record, the arm go back to rest mode but does not lift enough and scratch the record.....
I've opened the turntable. What do i need to do ? At least tell me what screws i need to adjust so i'll try that !
Thanks a lot
