I need your help with my system BV10-46 with BS/BM5 connected by masterlink in the same room, all speakers BL8000+BL6000 are connected to the BV10.
Yesterday I tried to connect a BeoLink Converter 1611 to the ML to get en AUX source. I did not succed with this attempt . After retrofitting I can not start my BS5 with the Beo4.
BS5 is set to AM Option 0 , as it was before installing the 1611.
When I change to AM Option 2 I may start the BS5 by using CD or RADIO, but the BV10 does not start the Labs and I get no sound.
Setting the AM Option on BS5 to 0, then using the CD or RADIO buttons on the Beo4 has no action.
I need your help because I'm not an ML master.
regards
gerard
