HELP!! Beovision 7-40 DEAD
switched on the BV7-40mk3 this morning to be greeted with the following
No sound - speakers did switch on
White LED info display full brightness and staying on
No picture - screen in a state of standby no backlight nothing just DEAD
no able to switch to TV DTV or RADIO CD
Not able to switch to standby from remote or any connected link room, also link rooms failed to accept local commands via remote or keypad
disconnected TV from the ML and power for 1hr, then powered up no ML just TV  waited 30mins while in standy, the pressed DTV on remote and Nothing  same symptoms as above  TV is less than 4years old and still under warranty
prior to this an engineer has replaced the pin module and twice the main board with the dvi and hdmi ports on  it on sw9.x
have contacted engineer,  but wanted to get some help on here as I got no TV for the weekend
Any update? I think it is a very unpleasant situation.
Any chance you might have a problem in the wall plug thus not giving sufficient power? Might be silly question but would prefer that instead of a TV failure/damage.
STILL DEAD 😡
Hamer💡
I would leave it a whole day out of power not linked etc
Then I would probably check again. Still if course even B&O some times stop working !!!
