Just had a quick demo of the Beoplay A9 Mk2 against the Mk3 at the dealership in Dubai.
First thoughts is that the bass was less punchy on the Mk3 on a flat equalizer. Managed to bass boost eq to +5 to get similar bass impact on a Dave Brubeck track which was quite acceptable .
Made a down payment on the Mk3 (Going with the philosophy newer is better) but I am a bit worried. I need to connect my turntable and or the streaming server which has a line level output (Built in switchable preamp). I noticed some specs on the B&O website .
CONNECTIVITY
1 x USB iPod/iPhone/iPad connector
1 x Line-in
1 x Ethernet
Beoplay A9 3rd generation
1 x Line-in / Optica combi-jack
1 x Ethernet"
Can anyone explain what the "1 x Line-in / Optica combi-jack" is?! Couldn't find a A9 Mk3 manual online and the dealer does not know either! Can I connect a regular line in; either 3.5mm mini Jack or LR RCA? I am avoiding the optical only feature as to avoid any latency delays. Can someone please advise if this takes a regular line in or is it ootical only!? Thanks all
a
