Help ....advice needed. Beovision 9
Faulty Panasonic plasma panel inside. New panel required. Source a late model 4-50 and get B&O Service to exchange. about the only option.
or..
Scrap the TV, re use the Beosystem 3 as your audio processor and get a big panel
OK, to be fair when it's on you can't notice the lines but for what it cost me it would not be worth it..toget b&o To fix it. As for the bs3 I assume it can be used with another make of screen/TV?... If so would be cheaper buying an oled tv and fitting to bv9... I assume you would just connect to the bs3 or is it more involved with special type cable etc etc?
or..
Or, depending on where you live, find a same generation (D# designation) panasonic "pro" on ebay or the like (saw one in UK for 110 in a ship case) and exchange the boards from your old one to the new. They just plug in the bottom after 2 screws. Don't have a clue how to take the BV9 frame apart but the whole system appears modular.
My motorcabel is unplugged. How die you manage to get it back in?
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
