Help !
I have a BS3200 with the hard drive but limited to songs copied onto it, most of my music is on a laptop , i have heard about apple tv and wondered what you guys thought, i would like to play music through my B& o speakers and photos on tv would also be good
Any suggestions would be appreciated
It's a great device and I absolutely love it in conjunction with an iPad. Please note that the latest Apple TV doesn't have analogue output so you'll need a DAC to hook it up to the AUX in of your 3200. If you just need audio and don't want to buy a DAC, look into the Airport Express.
All true ... but if you want music AND photos (and videos although you did not mention those) you need to look at the old (analogue outputs) or new (2010 or this latest 2011 version) MacMini (digital outputs)
Then you need to look at what connections you have on your TV to receive the MacMini video signal
We are all happy to advise ... but you will need to say if video is also a requirement ... and what sort of TV you have
I have a bv7 Mk3 - does that mean if i connect to the bv7 i could listen to the music through the speakers that are connected to the tv (which are Beolabs 4000 and 8000)
Yes.
According to this site link the BV7 MK II (or 2) was introduced into the UK in Dec 2005, and last sold in 2006.  Not sure about the Mark III's details.
This Apple thread (I am sure there are ones here) explain how to get around the interface challenge in case the Mark III does NOT have a spare HDMI port: link
In my case, my BV8 has an HDMI port that I associated to AV3 and Beo4 command [PC] and used IR blaster C2.  I helped Cliff setup his BV7 this way with one of the new MiniMacs. We are both able to get sound and vision over the HDMI connection.
We both use Phillippe's LinkPlayer to provide a Media Centre Menu that gains us access to all sorts of functions:
I have a Ps3 ,xbox,Sky and a projector occupying the HDMI slots and also a Wii is connected so not sure what my options would be ?
There is the HDMI expander ... I have not seen one but I have heard about it on the forum
