HDR2 - Pin code protected ??
Does the HDR2 have pin code?
I have bought a second hand HDR2. On the invoice serial no and pin code is mentioned.
But the manual does not mention pin code.
And B&O customer service in Denmark states that HDR2 does not have a pin code protection
I do not feel well about not having the pin code. 🙁
Any comments / experiences?
Hi, worry not! The HDR2 does NOT have a PIN number.
I am unsure as to why they have mentioned a pin on the invoice tho. You can check to see that the seriel number matches the HDR2 (back of the unit), it may simply be an error on the invoice or for another product.
Just thinking, did you buy it second hand or from a dealer? If second hand, this PIN is prob for another product.
Martin.
