Is it possible to upgrade a HDR1 80 Gb with a 250/500 Gb IDE hard drive (yourself)? I can see in the service manual it looks like a normal IDE hard drive and it also looks like you can manually can set the size of the disk in the service menu.
What format is the hard drive formatted in (FAT32/NTFS) and which format are the recordings store in, is it possible to plug the drive in a pc and copy the files and then burn them to DVD?
Regards Rasmus
