HDMI to YpbPr - Beovision7-32 MKII
Dear Everyone,
I have a Beovision 7-32 MKII - I have tried to connect chromecast with HDMI to DVI-I. Picture is perfect, but as many of you may know, with no sound to the beo 7.2 speaker.
I got a tip from a person who are using HDMI to YPbPR on a BV7 MKII and this works perfect with sound and picture. unfortunately, he dosent know how it's works since a B&O technicial did it.
Now i have bought a HDMI to YPbPR converter. (Same as link)
link
But i got no picture - I've tried with setting to choose HD-TV to yes YPbPR at D-TV. Is it something with settings or what can i do to make this work.
Look forward to hear from all experts.
Thank you in advance!!
HDMI out is wrong, should be HDMI in and YpbPr OUT (and into the BV).
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
linkwcB
Hello, I think you bought The wrong converter!
What you need is a converter with HDMI in and YBPBR and Audio out!
I have the same configuration and I use a HDMI to DVI converter with audio out ,everything is OK!
jesperhj wrote:
Dear Everyone,
I have a Beovision 7-32 MKII - I have tried to connect chromecast with HDMI to DVI-I……....
I have an Apple TV 4th generation.
I have already posted the settings in BV7 in this forum, in this tread:
/forum/imported-unmapped/beovision-7-40-dvi#post-2189161
I still had my FirevTv stick on the BV7, the Apple TV Gen4 runs with the same settings!
I suspect that the chromecast will also run with these settings.
Over the years the mystery of B&O 7-32 connections Roku 2720 worked for me ,👍 old device I do not think you can buy it now perhaps second hand still a viable?🤷‍♂️
