HDMI distribution to link room
I have just purchased a beovision 8 32" for the bedroom and will be coonecting via masterlink to a beovision 7 32" in the lounge.  My primary video source is SKY HD and would like to recieve the HD signal in the bedroom as well.
I know that masterlink will distribute via RF the picture and sound if I hook up the sky box with SCART but is there any way I can use an HDMI splitter on the Sky box and get the beovision 8 in the bedroom to call up the local HDMI socket whilst still sending the IR control commands via masterlink to the BV7?
Warren
Hi
If you ask B&O they surgest a "Atlona HDMI matrix" to link HDMI signal.
I have purchased a HDMI splitter 1 in & 2 x out, as i currently only need HDMI signal, linked to 2 sources. BV10-40 in main room, and BV8-40 in bedroom.
In my setup, the HDMI source is my PS3, that i use as Bluray/ DVD/mediacenter.  from that i connect the HDMI cable to spiltter, and distributet it to the 2 rooms.
Setup DVD source on both TV´s  And then i connectet both of the PUK IR-cables. from each TV, to my PS3.
Now i can control and se HDMI picture from both Main room and Linkroom.
But with all that said... could´nt you just buy a CAM Module for the BV8 & the BV7... plug in you Sky-card, and reseave it that way directly to the TV without the SKY-box.  ? ? ?
I was going to use an HDMI splitter but was hoping to not have to run both IR cables back to the sky box hence a method if using Masterlink to send the IR control back via the video master...
I don't think the CAMs are compatible with SKY.....  as SKY doesn't follow any standards...
