HD input on Avant 32
I'm wondering if anyone has any advice on connecting HD component to a 32" Avant (US spec/no SCART).  I see 2 HD options (RGB(5 connectors/YPrPb (3 connectors)  I've tried a Tivo and DVD player, both of which have the standard red/green/blue component (I've never seen the 5 connections before).  I've tried to select both generic RGB/Y in the SAT and DTV, no pic shows, but it will have show if I use the composite.  Any suggestions, do I have to deselect something?
So might it be that I just have to set the Tivo output to 480p?  I assumed it would auto-output.  Or with the Avant picture (gorgeous BTW) 480p isnt that much better than 480i.  Funny, I've never seen another product with the 5 connector BNC, also was confusing since usually RGB is the generic term for YPrPb, and the color of the connectors.  Thanks for the advice, I'll see if setting the output will be a solution.
You should be able to just connect the component connector from the Tivo to the Avant. You probably do need to select 480p output on the Tivo. The Avant cannot downscale like more modern tvs do.
The 5 connector BNC was more common back when the Avant was introduced. BNC and VGA were common connectors for projectors back then. This got VERY frustrating with the BeoSystem 1 -- which is basically the Avant chassis without the tv screen. It was nearly impossible to find third party tv screens that were compatible with the BeoSystem 1 requirement for VGA or B,R,G,H,V.
Something worth mentioning is that many of the earlier Avants were prone to getting a horrible magenta hue with video content going through the HD input. The Avant came out at a time when HD was still in its infancy and the Avant often had this fault. Sometime the magenta hue would happen after awhile. Unplugging the Avant and the source device from the power and restoring power often set the video back to normal --- until the magenta hue returned later.
