Got a Beogram 4000 and RX2 turntable...need advice
i found a beogram 4000 (without the platter) and an RX2 (without a tip?) . I got both for $16 without knowing much of the brand. I got the rx2  working or at least spinning. The 4000 is in good shape and heavy but os missing the platter.
i may keep an eye out for a cartridge for the RX2, but I’m a dumpster diving treasure hunter and a broke one at that.
The 4000 has me really intrigued though,but how do I find a platter for it? What other models have the same platter? The 4002? And then, I know how to find a cartridge, but after all that expense I may find it doesn’t work mechanically or electronically and I have other projects I could work on. But still, I really really want to get this 4000 spinning again.
any ideas on how to proceed? Where to find a platter for the 4000?  I’ll post pics tomorrow
The early Beogram 4002 turntables have a similar constructed platter as the Beogram 4000. The Beogram 4000 platter however has strobe markings on the underside because the BG4000 uses a neon strobe bulb to show the speed (via the strobe markings). The Beogram 4002/4004 turntables don't have that feature.  link to some pictures of the early type Beogram 4002 and later type Beogram 4002 platters. Half way down
I recently sold a bg4000 platter to Craig here on the forum, he might sell you his poor condition one if you don’t mind it looks a bit corroded.
If you want a better condition one, I might be willing to part with another one, but it will cost more than that bg4000 cost you.
The last bg4000 I saw for sale with no platter sold for £90 ish if I recall rightly, so you got quite the bargain there.
You should be able to test most of the functions without a platter, but if you don’t know what you are doing be careful not to make things worse., I would agree with sonavor that it probably has some issues.
Alistair
Thanks for the info. I had been scouring the internet for hours and could not tell. I guess not having the stroboscope would be a deal breaker for me. But if later down the road I don’t find a direct replacement I might give it a shot.
I am definitely interested. Man I’d love to have this turntable as my main. I’ll message you.
