Getting around the remote 5500 Master Control Panel
I have what you guys would consider to be an antique system! It’s comprised of the Beomaster 5500 tuner/amp, the Beocord 5500 cassette player, the Beogram CD 5500, Beogram CD 50 and lastly the Beogram 5500 record player. It connects to a couple of tower speakers and two bookshelf speakers (B&O) but my MCP 5500 units are both non-functional. Is there a way to navigate the B&O system without that remote?
Dan
Most functions can be done using a Beolink 1000 but some programming etc. can only be done on the MCP.
So, the simple addition of the Beolink 1000 would do most of it?
For example, I would like to be able to do at least the following:
1). Change volume,
2).  Select the component to be played, and
3).  Be able to (via IR) remotely affect these things.
dan
AND a Nakamichi tape deck! 😃
1). Change volume,
dan
Yes, a BL1000 would be fine for day to day operation, including the things you have listed above.
