Get rid of "soap effect" on BV 8-40?
Alen wrote:
Press the MENU button on the remote control to get into the ‘Setup Menu’. - Place the cursor on OPTIONS. Press RED button and within 3 seconds press GO.
Turn off FILM MODE in the adjustments menu!
Simpl.
BS 1, Beo 1, BL 2, BeoCom 2, 2x LC 2, Form 2, BS 2, 2x BS 3, BS 4, 2x Beo 4, BS 5 + CD rip, BM 5, BL 5, BL 6000, Beo 6, BS 6, H6, BL 8000, 2x A8, BV 8-40, 3x A9 Keyring, BL 12 - 3, Serenata, BeoTime, BeoTalk 400, B&O Bottle Opener, BV Eclipse 55 My LEGO
Thanks Aleyn
FYI mine was set to AUTO
Do you know what determines which mode it is in ?
My AUTO seems to always default to GAME MODE regardless of source and content ...
No, I don't.
I suggest you to turn off GAME and FILM MODE
Game mode is always on. Helps a bit. Is there a film mode on a bv8-40? Where?
Thank you! Very interesseting. Looking very much forward to try that after the weekend.
Are there something like this on a bv11? My bv11 are always on monitor mode, but I think the picture is a bit unsharp.
Thank you, I think it worked to take off the film mode. I have tested it today. :)
Kind of ironic that the film mode makes the TV so much less film like isn't it?
yes very much, - I have also thought about that :)
