Get rid of "soap effect" on BV 8-40?
How do I get rid of the terrible soap effect on Beovision 8-40? Game mode helps, but it still are there. Any other things you can do?
Does this mean you have fixed the system module problem 🀞🏽
hehe, no. Always when I am buy new technical stuff I got to try more things. Right now I considering to but another tv, if I can get rid of the soap effect and the masterlink does not work. :)
The soap effect is called motionplus on Samsung tv.
I am not a hard. Ore gamer ... just some ATV4 apps like Lara Croft πŸƒπŸ»β€β™€οΈ so the soap effect has never been an issue
The soap effect completely destroys a good picture. I cannot stand looking at the news or a film, where it looks like they are everybody dancing. I can completely reject a tv, if I cannot turn off the soap effect.
Seems that I missed something there.
Never noticed that on my previous 8-40.
But maybe that is just me ;-)
Nor me.
I have tried to adjust the GAME MODE but I can’t work out how to change the setting ... quite strange:
I guess hat the op is experiencing this on all sources and thought that the game mode could help.
I never used game mode on my 8-40.
Actually I think, that the picture is quite well.
I only replaced it to get a bigger and never (BSys4-based) tv....
....not because I disliked it.
What source are you using?
Never noticed a soap effect... might be your source....?
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Press the MENU button on the remote control to get into the β€˜Setup Menu’. - Place the cursor on OPTIONS. Press RED button and within 3 seconds press GO.
Turn off FILM MODE in the adjustments menu!
Simpl. 😐
