BV7-32" MKV will arrive in may 2009, with DVB-HD and a "little" BSy3 (official) 😕
future of beovision 7-32 ?
thanks guys, for your input. although your info is based on rumours i think i tend to believe them or is it just my wishful thinking
fact remains that this info was not mentioned on the last cannes dealer conference.
As I said, talking to your dealer is the best way to secure information - they don't tell you rumours. If they know a new BV7-32 is on the way, it's on the way!
The key point is that you can't buy the new BV7-32 right now and, if it can't be ordered by your dealer, it won't be here within the next couple of months either. Speak to your dealer.mhoutman:
my dealer (key dealer) apparently doesn't know anything about a future release of a new beovision 7-32 (8-40 and 7-40 blu ray are known to him)
here i must believe him.
Hi guys, sorry P-IN-P does work on the BV7_32 but what i meant was since there was no multiple HDMIs, then you could only P-in-P into the most used functions:
DVD + DTV
DTV + DVI
DVD + DVI
My self, I also what to PINP from:
STB + DVD
STB + PS3
PS3 + DTV
STB + DTV
This allows me, to watch 2 TV channels at the same time, i.e. listen to the music from a video clip but actually watch a movie that ive seen before, or listen to music on the PS3 on one side, while im watching TV on the other to, waiting for a film to start...
I would also like to have more DVI/HDMI sockets on my BV7-32, however HD sources are not as crutial on a 32 screen. There is a HDMI expander available as well.
As to the question whether there will be a MK4, well, there surely will be, we do not need rumours for this. It is true the current BV7-32 lack behind in term of specs, and B&O has to come up with an updated model. The presence of a DVD-HD tuner is soon to be compulsory in France for example.
p.
Apparently I was told in order to upgrade the DVB-S/T card I have on the BV7-40 to a DVB-T HD, I would loose the Sat tuner... not really worth it.
Im gonna wait until the PS3 has an HD Tuner on it i think...
okay i have some new insights.
my dealer contacted b&o and was told that release of a beovision 7-32 mk iv is imminent (well in the near future ) .
yet modifications only seem to be related to the screen and not to any connections. latter will be confirmed a.s.a.p.
