future of beovision 7-32 ?
i am still temped to buy one but on the other hand it misses features would could be part of a future upgrade. it is just the 7-32 screen size which suits us very well
so are b&o turning in upgrading bigger screens only (see the 2009 blu-ray upgrade for the bv 7-40) ?
Please dont buy it!!!
I bought it and im so thankful it was faulty to return it!
Get an AVANT 32 DVD
for the time being until there is a decent release of it
Is it so terrible😂
Personally, for the money, I think so.
No HDMI for crying out loud! The BV7_40 has 4 HDMI and the BS3 and its bigger for £1,500 - £2,000 more.
Loads more, granted but worth it.
Whats going to happen with the BV7-32 when you need to connect multiple sources? You will need an 4xHDMI to DVI hub and all sorts of other cables to make it work. Also, some products might not work because they assume that if you are using HDMI then the audio will travel down that route?
Bla bla bla...
I've been told that there will be a "New" bv7-32 in 2009
Ok, that might be interesting, although it might just be an addition of 2 HDMI Ports... it should be well worth the wait!
By who?
exactly weebyx, thats what i heard as well... thus the 2 HDMI
