Hello
For over two years now I'm been plagued by software problems with my various bang and olufsen products, including the beosound 5, moment , beoplay 1. This necessitated various correspondence with Denmark. After multiple requests a teleconference with Denmark was set up and my moment worked for about 6 weeks without any issues. Short version, stopped working properly and I took the product back for a refund.
My latest issue is with my Avant 55 Mk 1 (which is still less than three years old and under warranty). My Avant is integrated with a CORE using the B&O app to access NAS, TuneIn and Deezer.
The issues now are:
1. Music will not play via Avant and connected speakers for more than an hour without switching off (we've checked timers and its nothing to do with that).
2. If the avant/ core is joined with other multi room products music starts to cut in and out and is not useable.
Technicians have visited a couple of times and suspected a software platform fault. They have spent hours and hours testing all equipment.
I've emailed Denmark about this several times, I've not received any response at all. Just silence.
The technicians participated in a teleconference with Singapore team to discuss. Singapore confirm it is a software platform issue that is incompatible with other products.They don't know if an update will be coming for the Avant Mk1 (even though my TV is only 2.5 years old and bought new from the show room).
A work around is to connect my beolabs directly to the core, though this will mean i can no longer have my speakers work with the TV.
Im tempted to try and return the TV and the electronic wall bracket and ask for a refund. Interestingly just called the only Showroom left in the country who suggested that if I can watch tv then there's no issue and there are possibly no grounds to suggest refund!
Any suggestions? I've run out of patience with the ongoing software issues.
David
