I need to extract audio from masterlink to a 3,5” minijack TRS (Tip Ring Sleeve)
Should I connect it like this?
Masterlink >> minijack
White/Orange -L >> Sleeve
Orange +L >> Tip
White/Red -R >> Sleeve
Red +R >> Ring
Orange +L >> Tip
Red +R >> Ring
Connecting like that would give you zero volume/sound. You should be able to get sound by connecting sleeve to masterlink shield and red and orange as you figured out. Problem here is that you are opening masterlink to outside noise as the balancing is effectively lost. Best idea would be to build an active circuit that would convert balanced to unbalanced signal like BeoLink Active does.I need to extract audio from masterlink to a 3,5” minijack TRS (Tip Ring Sleeve) Should I connect it like this? Masterlink >> minijack White/Orange -L >> Sleeve Orange L >> Tip White/Red -R >> Sleeve Red R >> Ring
Oke, first I'll try without the BL-Active, solder a minijack straight to the ML, and go from there. If there is too much noise in the rest of the existing ML-wiring I will add the active kit.
Thanks for both answers!
