FROM B&O TO Sonos
Ahoi -
I have inherited a B&O system (Beomaster 7000 +Phone + CD) with Beolab 8000 Powerlink speakers … and would like to pipe music into my existing Sonos system. I have acquired a Sonos Connect and a splitting connector for connecting it to the B&O.
The B&O plays nicely on the two Beolab 8000 speakers. I have setup the Sonos Connect, and it is visible from the Controller (both as a ‘room’ and as an audio source).
However, no matter what I do I cannot get the B&O output piped to Sonos.
Can anyone help me, please.
Brgds Ivan
I'm not familiar with Sonos, but it sounds like you need to get an output from one of the Tape Recorder sockets to the Line In on the Sonos - If on the Sonos they are RCA the a 5 pin din to RCA cable will do the trick if it is a 3.5mm jack then DIN to Jack. Steve should be able to help, But I am pretty sure the output will be from the Tape Recorder sockets - then select Line In on your sonos
Ivan wrote:
I can now ‘play Sonos’ on the B&O speakers and ‘play B&O’ on the Sonos speakers. The surprisingly simple solution ended up being:
  • use the Tape socket on the B&O to connect to the Sonos Connect input (5 pin DIN → 4 RCA)
  • pipe the Sonos Connect output directly to line input on the B&O speakers.
Does that mean, that you don’t have the BL8000’s (PL-) connected to the Beosystem anymore?
