Guys and Gals i am in the market for a freesat HD recorder and wondered if anybody has any good recommendations which can be controlled by the Beo 5. I have looked at the humax one but i am sure there are other ones to be had. This will link up to a BV 7 40 inch MkIII. I already have a sat dish from my previous sky box which is still in place. Your thoughts and recommendations will most appreciated.
Freesat HD Recorder
There are not many units on the market for "Freesat" yet, but I would go for the Humax box because:-
- There is already a PUC entry available in the B&O library for the HD Freesat box
- In my view it is currently the best unit on the market, but clearly there are currently not many different types available
- As the remote uses NEC protocol it can be controlled DIRECTLY from the Beo5 with full functions of the original remote including "repeat" functions if you do not wish to use the PUC functionality for any reason.
Will upgrading to the latest STB-C eeprom (4.01 ??) which contains several Humax entries give me any support for a Humax or any other Freesat box??
Regards
Richard
Richard,
The latest STB-C western European version is 4.11
Version 4.01 supports the following Humax products:-
HUMAX Cl-51 OOC
HUMAX CI8100PVR
HUMAX DTI-41 00
HUMAX F1-VACI
HUMAX HDCI-2000
Humax IPVR 9200C
HUMAX PR-HD1000
HUMAX PVR 9200T
Version 4.11 supports the following Humax products:-
HUMAX Cl-51 OOC
Humax IRHD-5000C
Humax IR-FOX C
Humax IPVR 9200C
HUMAX PVR 9200T
HUMAX HDCI-2000
As all Humax use NEC protocol and assuming they all also use the same product address code which would need to be established then most of the common functions are likely to work.
Richard,
HUMAX Cl-51 OOC
HUMAX CI8100PVR
HUMAX DTI-41 00
HUMAX F1-VACI
HUMAX HDCI-2000
Humax IPVR 9200C
HUMAX PR-HD1000
HUMAX PVR 9200TVersion 4.11 supports the following Humax products:-
HUMAX Cl-51 OOC
Humax IRHD-5000C
Humax IR-FOX C
Humax IPVR 9200C
HUMAX PVR 9200T
HUMAX HDCI-2000As all Humax use NEC protocol and assuming they all also use the same product address code which would need to be established then most of the common functions are likely to work.
Keith,
4.11 also has HUMAX FOX SAT HDR on the list, I know because i've just installed it on my BV5 😁. the part number is 8344785.
Keith and guys thanks very much. it certainly looks like the humax all the way. It ticks all the boxes. Thanks again.
Thanks for the update about the Humax Fox Sat HDR, I will add it to the list.
