Foxtel Button
Hi guys;
Is it possible to program the arrow buttons on the Beo5 to fast forward and rewind without having to press the go button. I have macro buttons setup on the screen which press go and fast forward for instance, but was hoping i could change them to the hard key arrows. I'd assume you would be able to.
Also is there any way to program the Beo5 remote yourself or must you take it to a B&O store, do they have the software for download anywhere. Also if i did this would the software pull my current settings or would i have to start with a blank screen again?
anyone?
The Foxtel R/C is very similar (well almost Identical) to the Sky+ or Sky HD remote. Maybe someone from the UK has programmed a Beo5 to do what you ask. While I have a Beo5, I must admit I haven't bothered programming it because I find it rather unwieldy and rather useless. I stick with the Beo4.
You can get the programming software, and bring in whatever was set up on your Beo5, then edit it.
Regards
any idea where i can download the software? is this the same software the retail stores use?
if you could post a download link it would be greatly appreciated.
seriously, could someone please point me in the way of the download?
There's a heap of info in the Beo5 forums
see link
also see link
Did that help???
thanks buddy.
