FOXSAT HDR Box Humax
Hi.
Have just replaced a Sky Plus box with the Humax Foxsat HDR. I was able to access the Sky Plus box via BEO4 from several locations in my set up. Does anyone know if the upgrade software is available from B&O to provide the same capability for the Foxsat.
On a TV which can have the PU flashed from a laptop, the software is available and works fine.  I don't know off the top of my head if it's available for older TVs which need a new chip.  Since you're talking about an HD box I guess you are talking about a fairly new TV anyway, so an engineers visit from your dealer can update your PUC.
You do of course need the Scart cable connected in addition to the HDMI, to allow the picture and sound to be distributed to link room sets.
If you look in the GROUP (menu button above) or link you will find the currently available boxes for the PUC
For the STB-C in older Beovisions is also in the GROUP section and
Hi I am just waiting for my humax foxsat hdr box to arrive, have you manged to resolve all of your problems and is the unit working as you expected, could you also advise where the blaster needed to be fitted from the tv to the numax box, regards
BP wrote:
Hi.
