Afternoon all
Wondered if anyone can clarify the following:
I have a multi room ML set up but to enable some decorating I've had to take apart a ML junction box and separate the ML cable and the ML "socket" end in order to thread the ML cable through a hole that was too small for the box to fit.
Am I correct in saying that until I re-connect the ML cable to the junction box and also the ML "socket" end my system will NOT work?
thanks v much
