Floor stand Beolab 3
Can anybody help me with the height of the Beolab 3 on Floorstand ? Lets say the high from bottom of speaker to the floor and from top of speaker to the floor ?
I am thinking about changing my Beolab 6000 to Beolab 3...-Does this make sense when I have BL8000 in front with Beolab2 and a 7-55 with Beolab 7-4 ?
Thanks.
I would keep the 6000s. Better match visually for 8000s. If you had ALT speakers for all of the fronts might want to switch.
Floor to bottom of speaker is ca. 625mm and floor to top is ca 835mm...
I would keep the 6000s and consider a change to the fronts - Beolab 9 or 5 would add considerably to the sound.
