Fitting STB-C to MX4002
Can you advise me whether it is possible to fit an STB-C to an MX4002? If so, what is the part number?
Hope you can help.
Many thanks,
Simon
Yes it is - all the later MX range can take them - I think the part number is 1403000. It is the same for all these sets. I have the instructions if you are thinking of doing this yourself. You may need a software update. What is the model number and S/W of your set.
I see you have posted on the official site - I wonder how long it will be before you get a sensible answer? 😎
Thanks for the quick reply Peter!
The MX is a type 7842 with SW version 2.0 and ML 1.1 I do plan to fit it myself so any instruction would be really useful.
Once again thanks for your help. Oh and by the way, I'm still waiting for an answer on the official B&O site........😕
Simon
Look under the manuals for the AV9000 - the STB-C fitting guide is there - there are pictures for both the MX and the AV9000.
when I looked at fitting a STB-C to my MX  all the guides do not list the 784x type. What stops me from fitting one to this model? Is there a software fix to allow this ie update/ downgrade?? Is it a physical thing or a software problem?
I hope someone can advise.
Regards,
Simon
The guide specifically mentions MX 78xx models so I don't see why not. Have you downloaded it? Check with your dealer. I am finally having mine fitted to the AV9000 on Friday so I will ask Terry when he comes.
Hello Peter,
yes I downloaded the manual and all looks fine there, but I have seen other material ie schematic overviews and STB-C listings which specifically exclude the 784x model. There is no explaination why! Also the STB-C is no longer available through B&O dealers. It looks like they stopped producing them in October 2006! So old stock only!!🙁
I did manage to pick one up on Ebay so will have a look at fitting over the weekend. My dealer is getting more "cagey" on owner fitment of parts and seems reluctant to pass of information now. Must be a B&O directive!!Zip it!
Anyway hope someone can enlighten me before I unhitch the TV from its wall bracket!😝
Regards,
Simon
I got a new one last month!
As usual Peter it depends how hard the dealer tries.............Huh?
I'll ask for you on Friday. Terry seems a good man and I am sure will be forthcoming!
