Fitting Avant 28 DVD with Surroundsound, is it difficult?
Well, the subject really says it all. I am looking at a used Avant RF 28 with DVD for around 430 pounds sterling, but unfortunately it does not have the optional surroundsound card build in. Is it difficult to retrofit and is it obtainable at all?
best regards
Christian
Strange! In my opinion all Avants with DVD had a surround module installed and for sure the Avant RF 28 did.
So this Avant doesn't have Powerlink connections?
The first models 28"  RF did not have this module fitted, it was an option! Later it became standard.
The 32" did have it standard from the first
Answer to your question, No it is not difficult if you know what to do. Try to get a fitting manual. Main thing is connecting a few flat cables, color coded so you can't miss it.
Succes Ernie
Yes I thought it was standard too on all DVD models, but then I saw a picture of this particular avant and nothing there.
Thanks Ernie. Is the module still avalible at a dealer?
best regards
Christian
Christian,
There are a copy of different Dolby modules that will fit the avant.
The early Pro-Logic version - 4 Powerlinks, no Sub.
The early Dolby module with 4 Powerlinks and a Sub with 2 Digital Coax as well.
The later Dolby module with 2 Powerlinks (for daisy changing) and a Sub with 2 Digital Coax as well.
It's a 10 minute job if you get the right one for the modle of TV. I'm guessing either of the later Dolby ones will work.
I think I may have a 'spare' one of these somewhere.
Cheers
GUY
I have a copy of the installation instructions which B&O forgot to take with them when they fitted one to my Avant. I am not sure if its still on the manual page of this site, but if you like I can mail it to you if you like.
Thanks, that would be very nice to have a copy of the installation instructions to see if it is worth the hazzle. my email is christianhaagerup (at) gmail.com
best regards
Christian
