Fitting a third pair of speakers to 9500, how, where?
Hello all.
First of all, apologies as I know little of the 9500 apart from always wanting one, which I now have.
Mine has been purchased with a pair of RL60, a pair of CX100 and a pair of CX50.
It also has the MCL 2047 thingy and 2 sensors for other rooms? Which looks complicated.
As I want all 6 of my speakers in the same room, how would I wire them to the 9500?
Can I just plug the CX50s into the power-link socket (whatever that means).
I don't want to use the MCL if possible as too many wires.
Thanks in advance.
Lee.
Just download the Manual on the B&O website… and you will find out how to attach (at least 2 of) the speakers. A second pair might work with the MCL sockets.
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/singles/BeoCenter9500_UK.pdf
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Why do you want to run them all at once?
Have you checked the foam surrounds on the speakers? They are probably rotten. First thing is to have them refoamed.
I have a large room where 6 speakers would work.
Their condition seems as new, vacuum packed since 2002!
Thanks,
I have all the documents, I was just wondering if there is a plug for a third set.
