FINE TUNING BEOMASTER 7000 WITH MCP6500
A couple of days ago, some background noise appeared on the frequency where my BM7000 stored one of the radio station I usually listen to.
I manually changed the frequency with fine tuning ( GOTO + >>  or  GOTO + << on MCP6500) till the reception was perfect without any noise, then I press STORE + NUMBER (7 in my case) to store it again with the new manually modified frequency.The system apparently accepted the command but when I switched the system on again after switching it off, I found the radio station stored on the old frequency again (= it seems that the BM7000 went back on his automatic "locked" chioce) which in few words means: background noise again !
I did the procedure again and again but no way. The BM7000 does not keep my manual fine tuning stored.
Did I miss something? Does my BM7000 need technical service? Do I need a BL7000?
Thanks in advance...
mauro
B&O (legacy) enthusiast since 1985
Hi Mauro
As far as i remember you can switch off the automatic locking. At the moment i don't have the manual or the MCP6500 at hand.
I made the radio setup for 5 beomasters and 20 stations in the last month but most of them with BL7000. But at least for one i switched off the locking with bl1000 or the MCP. If you don't find the possibility, i can have a look at my (new old stock) MCP6500 and try it for myself. By the way does the bm7000 shows "locked" when you choose this station?
Best regards and merry Christmas
David
That's simple, just press GOTO and the "locked" indication (as well as the AFT function) turns off.
But I just tried with my BS6500, and apparently the setting isn't stored in the FM preset; once you go somewhere else and then return to the preset, LOCKED lights up again.
As far as I can see, the exact manually fine tuned frequency is stored though, so another GOTO to turn the AFT off should return the tuner to the off-center frequency that was set up earlier.
But, it seems to me that the real issue is the Beomaster being slightly out of alignment if you need to play with fine tuning to properly receive a station.
