Hi guys.
I finally got my BV9. I have been putting money aside for ages and I finally came across a good deal, so I am now the proud owner of a BV9 Mk.III π
It's a tight fit between the BL1's, but I have to see if I can rearrange it somehow, (even though I last year ran all the wires inside the wall).
I have been very afraid, that it wouldn't be able to live up to my dreams, but I absolutely love it and I am amazed by the picture quality. I do have some viewpoints and questions, though and I hope you could give me some opinions and answers.
1. I actually think the sound from my Avant was thicker, more rich. On the BV9 the treble is very dominating, although I have tried fiddling with the settings.
2. Although the standard setting for TV is SPEAKER3, it turns on the rear speakers and if I look in the SOUND SYSTEM menu, it says something like Input: PCM 2.0, Output: "Dolby Pro Logic IIx movie speaker 5". I do not understand this at all. Also the frontspeakers are not nearly as present as they were with the Avant.
3. Antenna input. It has the DVB-HD module fitted, but it also has an analogue input on the TV chassis next to the HDR1 cables. Is this so the HDR can record without using the BS3s tuner??
4. I don't quite understand the TV/DTV buttons. On my neighbours BV10, they only use the TV button, whereas I have to use the DTV button, although we have the same TV channel package from the TV signal provider.
5. I'd like it to control my PS3 via a RE*BL, my Macbook Pro and perhaps a WD TV Live. How du I update the PUC list, and how do I see what's already in it??
