Few Beolab Penta -questions
Would agree with that. Chris has recovered his Pentas with blue cloth. And very nice they looked too!
If you want to refoam then check on ebay under Beovox repair and then follow the links to an excellent Dutch site good_hifi.  I have bought several rings from him for CX50/100s, RL140s and also a pair to fit an LX TV.
Brian
Ville Laustela wrote:
MK1 having only the source and volume. They have line in, speaker link (the 4-pin DIN) and speaker level clip- connectors on the bottom,
Hello,
I am going to buy a Beolab Penta MK1, with all connection as above. I will connect Mk1 with my Beomaster 7000.
I have some questions:
1+ which type of powerlink can I use? Can I use a powerlink, one end connect to 8-pin on Beomaster, another end connect to Line-in on Penta mk1?
2+ if I use a 2-pin DIN speaker cable, is it sound and display? I see 4-pin speaker for both MK1 and Beomaster 7000, but it is hard to find it.
3+ Is there any differrence about sound quality between Beolad Pente MK1, MK2 and MK3?
4+ Do Beomaster 7000 fit to MK1 to produce best quality sound?
Thank you and I am appreciate for your experience.
Giang Nguyen wrote:
Hello,
Anyone help?
Ok, let's try...
1) I think that powerlink was introudeced in Penta Mk II or later, Mk I doesn't have one and you can't use that (or you have to adapt it to fit line in on Penta but I don't think that makes much sense).
2) 2-pin cable is just the sound, for the display (data) you need the 4-pin cable
3) Don't know about that, I think they were technically the same, just some display updates?
4) Without having a BM7000 I think it will be quite good enough! 😐
I ask this question because I will use BM7000 to drive Penta 1.
Yesterday, I heard Penta 1, that was driven by Beomaster 6000 as pre-amp, that connected though line-in connection and play by CDP Wadia 850, about 3000$. The sound is very disappointed. And I don't think a speaker like Penta can produce such a terrible sound like that. The sound quality from my Beovox S45-2 driven by Beomaster 2400 is much better, in comparison.
I am wondering. DO the sound quality change if Penta 1 drived by BM7000?
Hello everbody,
I have a problem. I have just bought a Beolab Penta 1, that driven by Beomaster 7000. Connection by 2-pin DIN. After half an hour for listenning, I found that a beolab power amplifier is so hot. another one is normal and cool. Anyone know why and how to solve it?
I dont know whats wrong with your Penta 1s but I recall I never got my Penta 1 to run relaiable on normal 2-pin DIN. Worked as a charm on 4-pin DIN (called Speakerlink, or a older version of Powerlink). Also used Line Input (normal screened RCA) but that was on a BM5500 wich had pre-amp output. Think you need a special plug for BM7000 to get pre-amp output.
Cheers
MoglesMac
Actuallty, there is no problem on connection using both 2-pin, 4-pin speaker link and line-in. The problem I have met is after 5-10 minute playing, the power amplifier on Penta 1 become hot. I think there is problem with some transitor. Anyone can help me?
Worth pointing out that Penta 1 runs with different cross-over values to Penta 2 and some additional components.
It may be that for Penta 2 they sorted the mid-range issue. Certainly my Penta 1's are not as bright or accurate as my RL140's. They still have a more fuller sound.
I'm hoping to pick some cross-over boards from a Penta 2/3 for comparison if anyone has any?
