Few Beolab Penta -questions
Hello.
I have just bought a pair of Beolab Penta speakers! I paid... well, a lot but less than 800 EUR.  This is the MK1 (?) version, yellow screen showing source and volume.
They are quite nice, especially after cleaning all the fingerprints off!  Only a few very small dents, most on the back.
My main questions at the moment are:
1) Has the original cloth been black or grey? The cloths are looking a bit dirty, almost yellowed... Some holes too and I think I will replace them.
2) When used with my Beocenter 9000 (thrue the 4-pin DIN cables); what sensitivity setting of the three I "should" use?
3) There seems to be a slight buzz - with no signal applied. I recon there is some re-capping to be done? Also I'd like to recap the crossovers someday. The DIN cables are very long and of unknown quality and I will shorten them and check the plugs and their solderings.
4) The midrange speakers are of the foam-edge type. They are all intact (except one that has now a small crack when I pressed it when checking). The speakers have been already played loud and as the foams are still in one piece I will let them be for now. How much a good-quality replacement rings cost and can you recommend a specific place to buy them? I have never done refoaming but I am eager to try!
I have had them for only some hours and futher listening will show if there are other problems. Anyway I already like them, they are huge, but they look great. I was sorry to give the S75's in exchange but I simply haven't got enough space to keep them all.
Well done - Pentas are great!
1) The cloth is grey, never black
2 & 3) Consult the manual onsite and also consult our resident 'tech guys' on the forum for that!
4) for the midrange drivers i would just replace them with the B&O new parts, but Dillen and Medogsfat are very experienced in refoaming - so i would possibly ask their advice! 🙂
Enjoy!
Lee
The orange display makes me think that they will be Mark 2 Pentas. Do they have Powerlink sockets as well? If using speaker link and a 9000, set the volume to the middle setting - 40-80W .
That's interesting, I was reading the "From Spark to Icon" yesterday and there the clotch looks clearly black!
I remember seeing the different displays in the "Collecting B&O" book and I think that the difference was that the MK2 had the track number display added, the MK1 having only the source and volume. They have line in, speaker link (the 4-pin DIN) and speaker level clip- connectors on the bottom, I don't think there was Powerlink, nor have I ever seen one!
I will be interest to hear experts' comments on whenever I should replace the elements or just refoam them. 🤔
Sound like Mk1s then, though all the ones I have seen had green LED displays. I would replace the mid range units - they are not that expensive though clearly this is made up for by the number of them. You then know you have brand new units with no faults.
The B&O collecting book tells that the MK1 and 2 have yellow (a bit greenish perhaps) screen and the MK3 has green dot-matrix screen.
There is anyway some maintenance to be done; the cloths, midrange units, electrolytic capacitors in the crossover and power supply.... Anyway I have a deal with the seller and we can lower the price if there are any faults that I have to get fixed.
Anyhow I'd prefer to refoam the midrange units, if that is considerably cheaper (and if I can do that myself with good results) than buying replacement units. As there are eight of them in total!
Mark 2 are distinctly orange - much the same as Beolab 3000s. Mark 3s are completely different and are green dot matrix as you say. Best of luck with the refoaming.
Hate to disagree with Peter but I have never seen MK1 with green display. My examples have all had Amber.
The only green ones are the MK3
I would also replace the midranges. They cost less than £20 each and will save all that crap and glue and stuff!!
Attached is a photo of my Pentas screen.
Are the replacement midranges still available from B&O? Or from Dillen or some other source?
And here is the broken midrange speaker...
