– Is it possible to connect my DVD 2 to the BSys 4 and how?For connection of the DVD2 you will have to use the AV socket on the Bsys 4 in order to control the DVD2. B&O made a 9 Pin DIN to start start cable for this purpose. Not sure if that is available anymore. More info about this can be found in this thread Other old thread suggest that you can also use HDMI to connect the DVD2 to a TV, but you will still need the start connection in order to get control. Not sure how this is setup on the Bsys 4 connection menu.
