My Essence has stopped accepting Spotify connect. The Essence shows in the app, but when I press it, it will not change the output to the Essence. I did a reset on the Essence, no help.
Any ideas?
Any ideas?
Try restarting your phone and/or toggle WiFi on/of and wait a bit. I don't think this is a problem with the Essence, but with Spotify. Once in a while, my Spotify can't talk to my Chromcast or Essence.
Not any help I’m afraid, but I had the same issue. The dealer and I couldn’t resolve it even with an exchange essence. Gave up and switched to deezer, which is actually the only source it can play without dropouts and chrashes.
I am having exactly the same problem. it used to work and since last week it stopped connecting completely. I am using essence first generation. Does that happen as well with the 2nd generation?
Hi, I have the same problem with the MKI. Since one week no Spotify connect.
I contacted B&O support. They are looking into it.
I'll post here when I get a reply.
Contacelted support again, no news on the issue.
They said they would inform me when they know.
0
Maybe that's the reason ...?
Spotify is removing itself from a number of home audio speakers and receivers from the likes of Onkyo, Denon, Marantz, Bang & Olufsen, Pioneer, and Yamaha. Some devices are losing Spotify integration completely, while others will require firmware updates if users want to continue receiving built-in access to their music.
https://www.theverge.com/circuitbreaker/2018/2/6/16979102/spotify-ends-support-speakers-receivers-pioneer-denon
https://support.spotify.com/us/listen_everywhere/on_speaker/why-cant-i-use-the-spotify-app-on-my-speaker/
If so ...
."Manufacturers can update their firmware to be compatible with the new platform,” a Spotify spokesperson told The Verge.
