I have just installed an Essence in my office connected to BL8000 speakers.
All the connection are wired I do not use the Wifi. I have 2 questions :
What is the best way to play all the PC sounds (windows 10) on the speakers. I have tried Airfoil but It crashes a lot and the worst is the sound delay of 4-5 seconds.
When you listen to music the sound delay is not an issue but when you are having a skype it is a big problem.
THanks by advance for your help,
Best Regards.,
Matthieu
