I've got an Essence Gen 2 with an Essence Table Remote. This morning I came downstairs and began listening to music triggered by the BeoPlay App. I sat down in my chair and attempted to adjust the volume with the Essence Table remote. Nothing happened. I pressed the solid circle to pause the music, nothing happened. I thought the batteries were dead, so I replaced the AAA batteries in the Essence remote. Tried again, nothing. so I thought I might want to re-pair the remote. I opened up beosetup app and removed the paired remote from the Essence in the hopes that I could start fresh. Removed the remote, and used Essence manual to re-pair the remote, it didn't work. I used the steps outlined in the Table Remote Manual, it didn't work. I even tried to use the steps outlined in the "how to pair with an A6 or A9, but for the essence, by opening up the Beosetup app and initiating pairing from there, it didn't work.
I have confirmed that the Essence remote is set up correctly by checking the mode, LED A flashes which means it is not paired to anything.
I believe the fault is either something I'm doing incorrectly, or with the Table remote. When the blue pairing light behind my Essence box is flashing blue. I press and hold the top dot on the Essence and according to the manuals it should begin to flash. What happens is that the LED blinks for a split second rather than flashing. If I keep the dot held down, it keeps doing the same thing. blinks for a split second, pause with no led, and blinks again for a split second. If I remove my finder from the dot, it flashes every second. All the while the Essence's blue pairing light keeps flashing solid blue. Not even an orange.
Is there a way to perhaps factory reset the Essence Remote? Do I have to maybe factory reset the Essence to see if that'll work?
What am I doing wrong? Hope someone can help. Thanks in advance.
