Essence refuses to play ONE Tune In Station - works in Tune in App...
@Chris: It finally works. I did as you suggested and sent a note to TuneIn. Then it took another hour and then it worked. The workaround did not succeed, it was alwasy greyed out in BeoMusic, even when it worked on the Mac.
Hi Heribert
Are you sure its ok, that fast?
The station gives me a still a fault on the TuneIn website...
Normally it takes at most max. 48 hours to get a respons from the broadcast team at TuneIn.
I sended also the new url on the update page to their broadcast team and I'm waiting now to get a mail respons.
The url link I have giving you is indeed working on Safari and forwarded by me to TuneIn, but it could be that its not actually working on Beomusic.
It works on the Moment anyway.
To be continued...
TuneIn did not reply yet, but the sender started to work - perhaps they were already updating the station before I wrote. Most important: it works. Thanks again
Chris wrote:
This station changed its lifestream url and TuneIn did not updated it yet. Edit the station in the Tunein form on the their website and submit the new adress to the correct new url for this station on the form. In one day or a couple of days it will be corrected by TuneIn.
http://stream01.superfly.fm:8080/live.m3u
Does this trick work for other stations?  Tunein can no longer play J-Pop Project Radio and I was wondering if I can find the stream address and do it this way.  Any way to find the stream address, if so???
Is this the the stream your looking for?
http://streaming.radionomy.com/J-PopProjectRadio?.mp3
Thanks!  I will give it a try when I get home!  It would be nice to play this again directly from my Essence!
Many many thanks! Tunein does not have very many J-Pop stations, and it hit me hard when Radionomy pulled J-Pop Project Radio and its sister station J-Idols Project Radio from Tunein.  These were my two favourties to use with the Essence.  They recommended the app which works fine from the iPad, but now I have them back with the Essence remote.  The Essence became much more valuable to me again now that Tunein has my stations!
Glad to be of help. TuneIn removed a lot of radio stations because of the lawsuit between Radionomy and Sony Music.
I noticed that in the mean time TuneIn updated also the streams for the Superfly FM radiostation from Austria.
A while ago TuneIn removed also all streams from Jazzradio.com. I have a subscription on Jazzradio.com, so the only way to listen to the stations again on my Moment was to add them as a custom URL, or use the Jazzradio.com app and listen with a Chromecast Audio.
I added them with a custom URL to my Moment and it works fine, only missing the logo's on my Jukebox screen but I have the music again... 🙂
I noticed that TuneIn is really caring for its listeners, and if their is a radiostation changing its stream, submitting the form on their website with the new stream address you have is enough to have it back in no time.
