Can folks with some experience with the following devices please let me know if the following behaviors are possible based on what my use case may likely be.
I’m planning on having the Moment (or) Essence in a dedicated music listening area directly connected to a set of Beolab speakers.
I have an always on Mac mini with an iTunes Library, and twonky server running. I also have a NAS with Plex running, but that NAS currently doesn’t have much music on it. I can confirm that the Beovision 11 can “see” both servers in HOMEMEDIA, both Plex and Twonky, and I can choose from media between the two.
1. Can the Moment or Essence be connected to two servers at once (ie. Twonky on the Mac Mini and Plex on the NAS. I don’t need either device to consolidate the media or anything like that, but it would be nice if they could.
2. I have no experience with the Beomusic app, how does it access media located on servers on the same network, or does it?
3. If I select some media from the Beomusic app, and click Play, is it streaming from the phone to the Moment or Essence via what -- WiFi or Bluetooth? How does that work?
4. Let’s say I have a Moment or Essence in a different room, but on the same network, ie. they’re netlinked to the Beovision 11 which has a pair of speakers connected to it. What do I need to do in order to listen to music from the speakers connected to the Beovision 11, and exactly what, if anything will show on the Beovision 11 screen?
5. If I’m playing a piece of music selected on the screen of the Moment’s tablet, and I open the Beomusic App, will I see the piece of music playing on the Moment? With the album artwork? Is it basically like a two-way remote?
6. Let’s say I have both an essence and a Moment, how would I control both from the same remote, that is, what function key / button would I require for the Essence, which for the Moment? Or would one keypress operate both?
Normal 0 false false false EN-US JA X-NONE
That’s all for now. Thanks for all your help!
