I am using Spotify connect BeoSound Essence with BeoLab 17.
Over the last month or so nearly every time I use the system it stopped playing and I have to re-connect the beosound in Spotify. Most of the time this occurred at the end of a song.
I have checked the connection status through the beosetup up to ensure that I have a good connection and everything else seems fine.
Occasionally I have to turn the beosound off and on to re-set it as it does not re-connect.
Over the last week Spotify stopped to connect completely and I had to use airplay
Is this a problem with the beosound 1st generation? The software has not updated for a couple of years and I wonder if it is a compatibility issue.
I would be grateful for your advice as it is annoying to have to re-connect every time I want to listen to some music
