Does someone know what error code 0530-22-2A means?
I also noticed error code 1101 MDL.
thanks in advance,
Paul
thanks in advance,
Paul
Paul,
This error code comes from IC1 on module 7 which is the Teletext decoder.
The fact you are getting this error code almost certainly means you are not using the analogue signal and using a STB instead or the analogue signal is of poor quality.
Keith,
Thanks, I suppose it is the last one you mentioned, (because not using a STB) I will check the connections (again).
Paul.
